necessaryevil
- Apr 5, 2010
- 7
- salem,or.
- 1987
- ford
- 2.9
at about 45mph my roof on my b2 pops, when i slow down it pops back, is there any way to stop this?
Ihere's a brace across the roof just behind the doors. What usually happens is something has been on the roof and bent the brace down. It was originally glued to the roof but has now seperated. If you pull down the roof liner you will be able to see if it's bent or just seperated. If it's bent you can just jack it back into shape and then re-glue it with something like construction adhesive or if it's not bent just re-glue it, Had the same problem with mine when I bought it many moons ago.
-REP UP-Ihere's a brace across the roof just behind the doors. What usually happens is something has been on the roof and bent the brace down. It was originally glued to the roof but has now seperated. If you pull down the roof liner you will be able to see if it's bent or just seperated. If it's bent you can just jack it back into shape and then re-glue it with something like construction adhesive or if it's not bent just re-glue it, Had the same problem with mine when I bought it many moons ago.
