Sway-bar drop brackets
shadow88
CLOQUET MN
Was thinking about a 4'' rough country lift, where can you get sway-bar drop brackets? The info under the description says I need them, just trying to put a list together so I know what this will cost me:yahoo:
Jsommers
michigan
I dont have sway bar drops on my truck. Worked just fine until i took it off completely.
Jsommers
michigan
And the rough country still uses the drop plate which will interfere with your dana 35.
country0001
Stillwater, OK
Ford,Ford
They come with the kit. Put mine on a year ago. I have had no problem with the drop bracket. But i'm not very extreme.
shadow88
CLOQUET MN
Country0001 how long is your rear drive shaft?
country0001
Stillwater, OK
Ford,Ford
Its basically stock. I built mine using a 1354 front drive shaft from an explorer. I can measure it when I get home
4.0B2
Walls, MS
4.0 v6
yeah, it comes with it.
if you use the RC coils, ditch the sway bar... I dd'ed mine with no sway bar till I put the EB coils on it. The RC coils are so stiff it doesn't matter.
OR you could make custom longer links with quick disconnects and keep the sway bar up where it goes.
shadow88
CLOQUET MN
Thanks for the input, I'll have to round up a drive shaft
