wont stay running
rawhiles
kansas city
Ive got a 1988 bronco2 with 62,000 miles, ran ok for awhile but started dying and would restart but would die again infrequently. put code scanner on it and got secondary fuel circuit fault (96) Replaced fuel relay, didnt fix, replaced inertia switch, didnt fix, and the high pressure fieul pump and that didnt stop the stalling problem...any ideas??:bawling:
country0001
Stillwater, OK
Ford,Ford
Check the throttle position sensor. Just throwin that out there. Is it a manuel or is it an automatic?
H munster
1984 Bronco II
Use a gauge and chect the fuel pressure.
rawhiles
kansas city
Its a auto trans to answer the 1st and the fuel pressure is a steady 38 psi at the rail ....am going to check all the grounds today....
country0001
Stillwater, OK
Ford,Ford
Check ur tranny fluid. On my 92 F150 when the fluid gets low it won't run right
