1989 FX4 BII, resto-mod project
88_Eddie
Raleigh, NC
b2 looks good, is that just a body lift on it?
Boggin
thanks man, i am absolutely in love with the look of it. and yup 3" body lift. shes about an inch lower on the front because theres a couple hundred pound of steel and winch hangin off the front of her. the weight on the front deffinetly made a noticeable difference in height, before the rear was a bit lower but now shes pretty dead on level (sagged rear leafs)
kris97ranger
lisle ontario
2006
4 litre and 4.2 litre
looks pretty beastly id throw some gears and lockers into it an just run it like that. maybe snorkel.. paint but other then that id leave it
Boggin
today i ordered a set of 3" jeep coils, the ttb should flex pretty good with extended brake lines, f250 shock mounts, ext rad arms, and jeep coils
-Nathan-
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
whens that thing going to get some paint?
country0001
Stillwater, OK
Ford,Ford
I need to do a body lift on mine. Would make stabbin trannys easier.
Looks good.
Boggin
well my buddy who was going to paint it is gone to alberta till july, and i want to have her done and on the road by then. so im gonna get the ol man to do it since he done a few before, and done my old 88 2wd. so hopefully ill pick up some paint this week and get her done.
Looks good.
thanks
Boggin
radius arms mount ill make. will tie into the trans crossmember somehow. havent figured that much out yet.
Clay Lorance
Elwood,Texas
4.2 V6
BIIs lookin good Boggin. It looks cool with the 33s and old school white spokes. I like it!:icon_hornsup::icon_thumby:
Boggin
thanks bud! those rims are gonna be painted black soon enough lol
Boggin
and here is the radius arm itself. yes i am very bored today
4.0B2
Walls, MS
4.0 v6
if youre that bored... get to building the real thing!! lol..
looks good. i need to make some progress on mine..
crawlin91
Crawlorado
Planning and creating visuals will help make the final project closer to what you want, and help you think of problems that may arise before you cut and weld which saves on materials, time and money.
IF you go with that setup it would be easy to tie the xmember to the radius arm mounts on the part that hangs just below the frame.
Boggin
thanks alot bud, ill keep that in mind
crawlin91
Crawlorado
take a look at plumcrazys setup, I believe he built it that way. I did similar and it has worked out well.
Boggin
ok ill take a look at yours and his, thx
88_Eddie
Raleigh, NC
where's the cardboard model?????
Boggin
haha like i said, no camera charger.
on the bright side, ordered up some 3" XJ cherokee springs last night
