I have no idea, thats why I asked for pics
You are no help at all.
lol, Ok, now you're a little help. I agree with that assessment. I think the elements are stuck to the glass, which still renders them useless because you cant remove them and re attach them. I was hoping it would be a direct swap of the rear glass, but I think I am hoping too much. I would like to have a rear defroster though.Let me rephrase that. i have not had the time to investigate the procedure. But aren't those elements in the window itself. Therefore, the window would half to be removed from the donor and drilled to fit the hinges. That tells me that it probably won't happen for me, feel free to correct me if i'm wrong.
I looked at the rear defroster, Its stuck on the window, so my question is , can you buy a new defroster "decal"? That way you could just stick it on the current window. I have the wiring for it and it just plugs into the window.
Plus, the defroster isn't much good without the wiper.
Don't think its worth the effort.
like i have said before. if you can think of it, joel has likely done it.
You haven't seen copykats B2, its legendary.Good looking Bronco! Now I see that I need a rear wiper too....lol
Aren't you copykat's brother or something?like i have said before. if you can think of it, joel has likely done it.
nope. just a good buddy.Aren't you copykat's brother or something?
I was wondering if some came without it. This hatch either had the holes filled when the bracket was removed or Ford used the same hatch with holes and filled them at the factory. I just drilled out the filler and bolted mine on. Did the ones that came without the swing away carrier still have the cutout on the passenger side of the hatch?
