1,892,399.04 mpgThe answers determine if I stick with Chevy or make the switch back to Ford so please give me a reason to offload my POS Chevy.
Gonna check out the ranger side as well. Earlier models 90-94 I believe.^^ I knew that would happen. Thanks for the heads up on the carb vs efi. Is there a conversion from carb to efi?
Hope you don't mind too much. There's a serious answer in your other first thread.^^ I knew that would happen. Thanks for the heads up on the carb vs efi. Is there a conversion from carb to efi?
didn't even think about the fact the 85 came w/ the 2.8 carbed...^^ I knew that would happen. Thanks for the heads up on the carb vs efi. Is there a conversion from carb to efi?
Yeah but if you are shopping and want EFI just get one how you want it.^^ I knew that would happen. Thanks for the heads up on the carb vs efi. Is there a conversion from carb to efi?
