- Apr 13, 2009
- 205
- 45
- 28
- Red Deer, Canada
- '91, '93, '98
- Various
- 4.0, 4.0, 4.6
- Suspension Style
- 4wd
This one is the first 4x4 I owned. I've had it for approx. 2 years. I paid C$300 for it originally, and it came with a 4.0l already installed. It was a real rust bucket. It doesn't look to bad;
It seems I didn't get enough before pics. New floor board installed;
Brackets I built to raise the back of the body back up ~1 1/2" so it was back at the right height, bolted in place with riveted nut inserts. I didn't trust my welding skills on sheet metal at the time;
One pic of the rust on the outside;
And what I did to attempt to fix the rust with out much knowledge. I think it turned out O.K. and is still holding up. I bought the drivers side floor pan but everything else is scavenged, I used what I had on hand; like access panels from a house heater, dryer panels, venting sheet metal, and other stuff.;
I cut the rust out;
and repaired as best I could, the same being done on the other side;
There was a lot of rust in that b-II. If I had cut the wheel wells before fixing the back I think the whole body would have dropped down to the ground!
I then started on a front receiver;
I picked up a bolt on receiver for a different truck and adapted it to mine. I bought it for C$35.00 Unfortunately the 10,000# winch was stolen last winter.
I also installed a front pumpkin and rear axle with 4.10 gears. I shimmed the front side gears to make a limited slip.
Installed air shocks to help the sagging rear springs.
That pretty much brings it up to date. Total cost including 31" MT Baja Claws= C$1,750.00
Richard
I cut the rust out;
Richard
