country0001's Blue B2 build
Hazmat Ranger
May 2009 STOTM
North Texas
Ranger
Got hatch mounted today. Shimmed it a little bit to make it close better. Freakin love it.
Started realizing that I'm building my perfect B2. But its spanning over the entire run of the B2 production.
My truck is a 90 w a 94 ranger 4.0. It has the 90 A4LD w/ a 88 manual tcase( next weekend) I have 88 doors w manual windows, 84 rear hatch w opening window, 89 front clip and about 6 cans of rattle can flat black
Brings to mind that old Johnny Cash song "One Piece at a Time" LOL . . . will get a closer look tomorrow.
ForOffRoadDriving
HIGHLAND, MICHIGAN
3.0L
Too bad your not closer, ive got a set of 4 BFG MTs 30x9.50x15 that id sell for $100, but the shipping would be 3 times that probably.
country0001
Stillwater, OK
Ford,Ford
I appreciate the thought, that's normally the way things go on here. Someone on the other side of the country has what you need.
I've got some new ideas spinnin in my head. Probably in the spring, I'm going to swap in my D35 from my other B2. Gonna build my own extended radius arms and new tranny crossmember. The duff kit is 600 bucks, but it doesn't look that hard to do. I have more time than money.:icon_welder:
Still need to swap my t case. Just trying to find the downtime.
Found a D44 SA for my other B2.
disciplerocks
July 2011 OTOTM Winner
Evansville, IN
There is a guy over on broncoii.org that did a 2 piece hatch. Cut the hatch in half then used a Ranger tailgate. Its pretty badass, but then so is the opening window.
country0001
Stillwater, OK
Ford,Ford
Thats what i wanted to do. Then I found my hatch. Might still do it.
country0001
Stillwater, OK
Ford,Ford
Well, a4ld went out, gonna install my m5od from my other b2. Will installmy manual t case at same time.
country0001
Stillwater, OK
Ford,Ford
4.0 flywheel ordered today. It'll be in on the 19th. Gotta get my new clutch set in too. Next week,I'll be wrenching away! Yay
4x4b2
eastern oregon
2.9l v6
bout time it gets swapped to 5spd :p i told ya like 2 pages ago to do it but no...lol
country0001
Stillwater, OK
Ford,Ford
:headbang:Been fightin the ex wife in court. My lawyer got my lift,tire,rim and bumper money. Well worth it, but got me behind on my project. I won in court.
Time to get started. More good news...... The clutch set that I put in my other B2,can be damaged out and refunded as a part of my 4.0 clutch set. So my cost will go down considerably:headbang:
country0001
Stillwater, OK
Ford,Ford
Got my new flywheel today.That 4.0 flywheel is pretty beefy.
country0001
Stillwater, OK
Ford,Ford
new flywheel, yay!
M5OD donor, next project.
kris97ranger
lisle ontario
2006
4 litre and 4.2 litre
Maybe Tan will be my SAS w a V8. Hmmmm maybe a midengine B2 like gwaii's ranger.
JK, dont think its long enough, plus engine noise would be tremendous.
i know its from a while back but i wnted to point it out
gwai has a b2 with a mid engine 460 its his wheelstander. and when you finish the paint if you havnt already my vote is for camo racing stripes i think thatd be awsome.
country0001
Stillwater, OK
Ford,Ford
Will get clutch tomorrow. Time to get started
country0001
Stillwater, OK
Ford,Ford
Got the tranny pulled out of tan.Took longer than expected, my chevy friends had a hard time workin on a RBV.
country0001
Stillwater, OK
Ford,Ford
New clutch and flywheel installed. Tranny in and lined up. Got a few of the bolts in someof them seem too short.
Doing the tcase tomorrow
4.0B2
Walls, MS
4.0 v6
still debating on if i wanna do the md05 swap on my b2..
country0001
Stillwater, OK
Ford,Ford
Also did the pedal assembly and steering column swap. Steering column was nothing.
Pedal assembly was a booger.It only took an hour, but still frustrating
97fordrunner
New Richmond, WI
Ran into that on my old BII I believe the 4.0 flywheel is a touch thicker and you need different bolts. Got mine from the dealer but you could probably find them elsewhere. Looking good though keep it up:icon_thumby:
