- May 27, 2010
- 1,257
- 7
- Evansville, IN
- 1989
- 4.0
Anyone seen spindle nuts like these?
Hey, that looks familiar.
I think you mean D50.....Found them on an F250 with a HD44 TTB.
Nope it was the HD44. There was an F250 with a D50 there too.I think you mean D50.....
they use D60 hubs, so those nuts prolly too big for your 44....
l8r, John
No. I reused the 1.5" flange that held the XJ coils on the 35. That way I could use the XJ isolators. Then screwed in a 6" long pipe into it.is that a spindle on the coil buckets?
As stated, you are mistaken. F250's came with either a Dana 44HD or Dana 50 TTB. Most trucks with a 460 or 6.9 got the 50, where as most 351 and smaller trucks got the 44HD. However, there is a plethora of variations, and any combination you can think of. So one cannot assume that because it is a 250, it is a 50. The Dana 44HD uses 44 size axleshafts, 44 u joints, and 44 lockouts. Only the 50 uses 60 outers.I think you mean D50.....
l8r, John
Yes. They are a cartridge style locknut. The rear of a sterling 10.5 has the same setup, only larger.Anyone seen spindle nuts like these?
No, it is a one nut system, just line up the tab on the case with the groove in the spindle, just like you would the lock washer with a 2 nut system. Not sure the spec on that nut, but usually you torque it to a certain value, than back off a couple clicks.Thanks man. I am going to swap them in next time I have it apart. Should there be anything else? Another nut or is that the only thing?
