disciplerocks's B2 build thread
AgPete139
Houston, TX
4.0L OHV
Good you got home safely. That shit's gotta be nerve-racking, with a wobbly front wheel.
disciplerocks
July 2011 OTOTM Winner
Evansville, IN
No its not fun, but I'm kinda used to it after running the D35 for so long.
dangerranger83
Lafayette, IN
When did you notice that it was broken or what told you it did other then seeing the oil under it? Looks like it has just broke right where you parked it.
Sent from my A500 using Tapatalk 2
RangerSVT
Oct 09 OTOTM
TRS since 2002 - NW TN
2002
GT-40 5.0L EFI W/AC
Time to upgrade to tons :icon_thumby:
SVT
1986broncoiister
OREGON
hey im liking your rig but i think its mad at you for switching it to automatic lmao hope you get it fixed :headbang:
Jay'94
West lake Hills, Texas
HMMM? Isn't that Ranger SVTs old rear end? :icon_idea:
RangerSVT
Oct 09 OTOTM
2002
GT-40 5.0L EFI W/AC
I doubt it Jay. The one that broke was 28 spline and it was scrapped. The ex axle that was in it I believe he pulled the gears and used a different axle, this one is from a fw truck...
SVT
disciplerocks
Evansville, IN
Yes it is Ricks gears in a full width axle.
I noticed it when it went BANG, and I could no longer go forward.
RangerSVT
Oct 09 OTOTM
2002
GT-40 5.0L EFI W/AC
Have you pulled the cover yet?
SVT
dangerranger83
Lafayette, IN
Okay, it's tomorrow, crack that baby open.
I don't see how you broke a 8.8 setup.
kris97ranger
lisle ontario
2006
4 litre and 4.2 litre
Not to mention all the torque from a 4.0 and a doubler
dangerranger83
Lafayette, IN
But just driving to work... Hopefully a ring or pinion gear didnt bite the dust.
Sent from my SGH-T499 using Tapatalk 2
disciplerocks
Evansville, IN
Settle down people. I just got off work.
I snapped the cross pin. I have spares and would only be a 20 minute fix, but I don't have a spare diff cover. Mine won't hold fluid anymore. Plus I'm not sure if the carrier is compromised. I'll grab another since I will be diff shopping for the Focus as well on my next junkyard run.
And yes this was done at 40 mph on a straight road.
Hahnsb2
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Mini spools put a lot of stress on the cross-pin and never unlock to relieve the stress. This is why a properly welded diff is encouraged over a mini spool, it transfers most of the force through the side gears welded to the carrier instead.
