- Sep 24, 2009
- 16
- Walls, MS
- 1988
- 4.0 v6
actually 95-99 XJ would be ideal for the d30 purpose... larger 297 joints and high pinion.To the OP...
A lot depends on the use the vehicle will see. For a patrol type vehicle, I'm assuming a mild build, nothing crazy. IMO, a XJ would be the way to go. 91 or newer to get the H.O. engine and less problematic renix electrics. A 91-94 should also have a high pinion D30, which is stronger than a LP D30 in the newer jeeps. (LP, or low pinion, use a reverse rotation cut on the gears). A mild 3" lift, which you can install in your garage in under 2 hrs with hand tools, clears a 31-32" tire easily and still has really good street manners.The Explorers have a little bit more complicated suspension and are a little more involved install, although I'm sure it can be done in the garage. Explorers do have the manual hub advantage, but again, in a patrol vehicle, in an emergency, the ability to just engage 4wd on the fly, like in a jeep, is the way to go. Jeeps dont use vacum hubs either like some of the earlier fords, so more reliable 4wd that way. The NP242 case is also a great feature with 2wd, full time 4wd, 4hi, N, and 4L...which if you send the case to Terraflex, they will install the 4:1 low range kit, and the 2 low kit, which gives you 2wd, full time, 4hi, N, 4L, and 2 low, all with one lever.
Try to find an XJ with a Chrysler 8.25" rear axle, fairly common, this axle has very similar strength as a D44. An 8.8 w/ disk is an easy swap also, and cheap if you an weld the brackets on. The aftermarket support and popularity of the XJ means you will have readily available parts more or less at any auto parts store. Older Jeeps are often more well cared for and better maintained, at least in my area, than exploders, which are generally all beat to crap and junky. As far as off road and hard to access areas, the Jeep is going to get you in and out with less work and effort than the same year explorer. Especially when you pull the front axle sway bar disconnects. The mechanical aspect of an XJ is just better suited to rough terrain use.
Explores of the same era were not built to be used off road in harsh conditions like an XJ, they had less robust suspension and less travel, and were more based towards daily driving, occasional light off road use.
Ramblings from a Jeep addict....that's my .02c worth.
hubs? you could just leave the explorer's manual hubs in the locked position and the t/case in 2wd... same thing as the jeep lack of hubs.
explorers are just as easy to lift. the suspension is not as "simple" but just 2-4 inches and if you use proper steering, you have zero issues.
PLUS with ttb, you have the "go-fast" capabilities in rough terrain with the right coils and shocks.... will ride better than solid axles at higher speeds PROVIDING you get soft coils and good shocks.
I don't see how the cherokee really is that much, if any, greater than a first gen explorer.
but that's just my .02 cents from someone that is in a jeep club and around them enough to like them....yet owns basically an explorer (my 4.0 b2 is almost all explorer drivetrain) plus I have a first gen explorer.
