Todd
HCT
- Aug 7, 2007
- 29
- 1
- Troll land
- 90/91/99/04
- 2.9
So just got done swapping in one tons from built 35/44, 8.8 both geared 4.88 and welded. After being welded welded for many years I vowed that I would never wheel with an open diff again.
My 60 and 10.25 are open open with 3.73 gears. After I sell some of my old axle parts and tires they are getting geared 5.38 to spin my new to me 38x20 v bars.
The rear is getting welded next week, but before I wheel it I need a locked front. My next funds are allocated to gears as they will be needed the most. I was planning on then locking the front with a lock right when money dictates that I can.
One other option I have looked into is a “fuzzy locker”. This is welding, filling, selected teeth on the side and spider gears while out of the carrier. Both with preheat and post heat processes to ensure proper hardness of the gear is retained. By running this setup I can install the spider and side gears as effectively as a mini spool without having to buy one as savings is key here. Then when I have money for the lock right I can remove the side and spiders to install the lock right.
The one problem I see is the increased side loads created by this setup. From the shape of the gears when they bind up against the filled in gears outward loads will be placed on the carrier. From the side gears parallel to the axle shafts into the carrier, and from the spider gears parallel to the cross shaft. Now this is not what a mini spool does. A mini spool loads the cross pin in shear.
Do you guys think that a 60 carrier can take this for a year or less spinning 38x20 tires backed by a 2.9 with 3.73 gears then 5.38 gears and a doubler transfer case? I did flog on my old setup hard and only plan on going harder on it now.
And I don’t want to hear about steering and all that BS with a welded front, I DID IT FOR YEARS SO I KNOW WHAT IT IS LIKE. Just tell me if you think the 60 carrier can handle the “fuzzy locker” or have any other experience with it for that matter.
