Hahnsb2
- Aug 8, 2007
- Age
- 35
- Battle Ground WA
- 88-95
- Ford-Dodge
- 4.0-5.2 Turbo
OK I just copied this from my build thread on B2.org. I will keep it updated!
Well I dont have any pics of when I first got it because my comp had to be reformatted.
Heres the specs which I will try to keep up-to-date.
88 EB edition
94 4.0 From Sploder Sport
M5OD 5 speed
Manual 1354
Warn manual Hubs
U-joint rear driveshaft
D35 front, aussie locker, e-clip eliminator
8.8 31 spline rear, Aussie locker
4.56 gears
3" PA body lift
34x10.50 Super Swamper LTBs
Custom made bumpers front and rear, warn 6k
Rear sploder springs with overloads removed
Full 2 1/2" exhaust, flowmaster 40 series and a before tire exit that run between the frame and body so I cant smash it.
4.0 auto radiator
Half Doors for wheelin
2X100Watt off-road lights
Oil pressure, water temp and vacuum gauges added
Heres right after I put the wheels and tires and brush guard from my parts rig on it, last spring break.
Heres a pic of me on that same rock pile with snow.
Had to add this. See my sweet windshield crack?
I made onboard air for free with shit I had laying around!
Next came the 3" body lift and tires.
Body lift gap fix.
The I finally settled on an exhaust I like and one that i cant smash. Flowmaster 40, no cat (I have hi flow im gonna install) full 2 1/2" pipe and a 12" long 3" tip.
I have done many more things to it, I just dont have many pics...
Installed the rear 4.10 LS axle tonight, took it for a test drive and it feels like a rocket compared to what it used to!!! It also got rid of the terrible drivetrain slop it had. I hope to get the front in by sunday but I dunno.
Only pic I got.
Well still havent got the damn 4.10 TTB in yet :banghead: Weathers been crappy on my days off and the days I work its been nice (like right now). Ive only ben able to do small projects. I pulled the crappy non a/c rad out and slapped in a good auto w/ac rad thats twice as big and flushed the cooling system, hopefully it wont get over 200* anymore up in the woods. I also pulled my grill, masked it and painted the center portion gloss black. It lookin like the ttb wont be in till after spring break is over because I work all but 3 days of it and the 3 days im not worin ill be in newport :banghead:
My Lock-Right arrived today! Cant wait to put it in! Thanks Todd!
Well as I pormised, the 4.10 ttb went in today and we managed to get the lockright in too, what a bitch!!! Had to swap in an open carrier to use it, had to grind down the ring gear to get the full crosspin in, the notched 4.10 crosspin wouldnt allow us to put the c-clips on with the lock right because it didnt allow the spacers to move inwards, so out came the dremel and in the went the stronger un-notched crosspin.
I took it for a quick drive, couldnt feel or hear it click, deffinalty pulls to one side after you let off and give it gas but its only for a second and according to the booklet its normal, deffinalty wants to go straight if ya give 'er gas while makin a sharp turn, all in all it seems pretty damn streetable, im impressed! Of course its dry right now, it could be another story when its wet...
Out with the old 3.45s, Took about an hour to remove, not bad...
In with the 4.10s! took about 2 hours after swaping camber bushings, brake rotors and bearings.
Dad grinding on the ring gear, note the tape everywhere to minimize metal shavings in the diff.
Lock-Right in! Total time spent on the locker was about 8 hours! Who needs spider gears?!?!
I put the 4.0 radiator in today with some free time I had. I got the rad from Brian, its from the Danger Ranger.
Heres a pic comparing it to my old radiator from a 2.9 auto which is twice as thick as a 2.9 manual! So in short, the 4.0 auto rad is 4 times thicker than a 2.9 manual!
Heres it is installed, hopefully this means cool running for the 2.9.
Picked this up from Joe (BRONCMAN) this morning, and I installed it before I went to work, its pretty stout and fits very well. I had to do some minor grinding at the end of the frame. Its also made a for a 2" body lift, so it sits up like it should and the gap is much less.
Well I finally grabbed a door from the parts rig and started cuting it down today for half doors. I didnt get too carried away but I took a good 8"s out if it, I just cut then folded it over and welded it. I then too some of that black plastic trm stuff and put it over the the area I cut so I dont cut myself ( I already cut my finger before I put it on, damnit). I also slapped on an extra flag mirror to keep it "legal". I think Ill paint em black when Im done or blue if I can find a close match to my paint in a rattle can.
Finished chopping the other door. Now I just need to get another thing of that plastic trim and some spray paint and they'll be ready to slap on for some wheelin. Not sure how Im gonna work around the fact that my doors have power windows and locks so trying to snake the wires through the fenders is going to be a bitch, maybe a coathanger would work?
Here they are on the rig. They dont appear to be cut a whole lot but theres enough of a cut out to lean out just fine.
Well I started work on this bad boy! I added 4" c channel to my Smittybilt push bar and ditched the stock bumper, still lots of work to do like add metal on the top, d-rings, finish the ends, ect. Im happy with it so far :thumby:
I added some aluminum diamond plate to the top for now, not sure if Im gonna keep it or go with steel...
Well I bought some d-rings today for it. I went down to the shop again after school today and started welding on it and reinforcing it and added the d-rings on. Only real thing left to do now is finish the ends and the front pie shaped piece that will blend the inner and outer pieces together. I like how my welds turned out, too much spatter but changing wire speed wouldnt solve the problem so I just kept welding, it seemed to have good penetration.
I used some square tubing to help reinforce the outer pieces.
D-rings welded on.
Heres a shot of the brace again.
Here it is installed.
Well I did a lil more work today. Added the angled pieces that tie the ends into the center section and used a blending wheel to make it pretty smooth. I also capped off the ends of the c channel. I just need to beef up the mounts and get some bedlinder on it!
Thanks Pat! I plan on beefing it up soon before any major pulls happen. I bought some Duplicolor spray on bedliner today and sprayed it. I like the way it turned out! I still need to beef up the mounts soon but at least its protected from the weather now! I left the diamond plate bare, Im gonnaa see how I like it in the long run, if I end up not liking it Ill coat it too.
Well I started work on the spare tire carrier. I plan to make a hi lift mount too and possibly a jerry can mount. I just need to cap the tubes, weld on the latch and bed liner it.
88 EB edition
M5OD 5 speed
Manual 1354
Warn manual Hubs
4.56 gears
3" PA body lift
4.0 auto radiator
Body lift gap fix.
Only pic I got.
D-rings welded on.
