1BadRS
I am swapping out the C5 in my 84 Bronco II for a M5OD out of a 1991 Explorer. When we took the transmission out of the explorer and went to seperate the transmission from the transfer case it was sealed together with RTV. It is obviously not a part of the transmission that is exposed to the fluid since I can see a valley cut into the extension housing where it would all leak out. So that leads me to question why they ended up putting RTV to seal them together. Does Ford use a gasket between the transmission and transfer case? If so I'd like to get one before putting my 1350 onto the back of it.
Thanks
Thanks
