- Nov 4, 2009
- 444
- 4
- marquette, MI
- 2000
- Ferd
- 4.6
here's the overdue pic's. Look's like winter is gonna last longer than expected so there is a good chance it'll be goin for the spring breakup, Still alot to finish up on the motor swap. all the wire's had to be extended for the electric shift t-case and there is a bad ground somewhere both light's light up and wont engage into 4wd. also the tach isnt workin properley as is read's correct at idle as soon as you rev the motor it drop's to nothing. and runnin it with no MAF isnt to prime either. so still need to finish up an intake for it
here are some pic's of progress made over this winter.
the free waggy 44 almost ready to go in, still waitin for the SOA kit.
had to put on some caliper's and repacked all the bearing's
the free wheel's for the font and rear axle. and he may have stumbled on some free 35'' bfg AT's that still have LOT'S of tread
Rear bumper and tire carrier (I think i posted this allready)
I really dont like the channel but I guess it'll do that job
The new home for the battery vented to the outside. (box isnt sealed but what do you do)
Power distribuitin and computer location. If it look's like the computer box is on an angle IT IS. I built a vent into the box and any moisture that may happen to get in there(really hope none) will drain that way.
Bracket's made to hold the power dist* box and computer
and the booty fabbed air cleaner which will be changing due to the 4.0 MAF not fitting inside the housing.
