'86 Bronco II Eddie Bauer Restore.........
94STXRanger
Kansas City
Hey you dont have a stock Ranger Rad arm do ya?
mjonesjr
I dance with the Devil...
Firefighter
Salem, IN
sure do. $25 + shipping and both are yours.....
94STXRanger
Kansas City
ha alright. I broke the end of my shock bolt off. Any suggestions other than arms?
mjonesjr
Firefighter
Salem, IN
drill it out and replace it...you can grind it off close to the arm then drill.....
94STXRanger
Kansas City
just put a bolt in from behind?
mjonesjr
Firefighter
Salem, IN
yes....make sure you use a Grade 8 bolt...
mjonesjr
Firefighter
Salem, IN
I hit a junk yard up Saturday looking for my buddies '89 a new bumper. We found an '85 with a nice brush guard on it so I got it for $30. It needed cleaning up and paint, but that was easy. Luckly the bolts holdign it on broke lose without a problem. It was a tight fit under the BII to get the bolts off since it had no wheels and was sitting on the ground.
Before Cleaning:
After Cleaning (wire wheel on angle grinder):
Back Side painted: (1 can of rust-o-leum)
Front Side painted: (1 more can of rust-o-leum)
I hope to have it installed in a couple days...
mjonesjr
Firefighter
Salem, IN
no thanks. I like the stock bumper.
mjonesjr
Firefighter
Salem, IN
I had the front end aligned today. It was surprising how close I had it just by sighten it.
I also got my brush guard installed. Below is those pictures. Before anyone ask, I am NOT going to be running lights on it for right now. I am going to install my blue LED's on it sometime here soon. I am still deciding if I like it or not; either way, it will stay on there till after the Dunes trip so I will have something to attach my flag to.
mhughes165
have u figured out what todo about lifting the back yet??
mjonesjr
Firefighter
Salem, IN
Here is my pile of 1 FM-145 transmission (sold), 1 FM-146 transmission (getting installed in the BII), 2 BW1350 manual transfer cases w/ shifters (1 in my BII and 1 in my buddies BII), 4 driveshafts (2 front, 1 double cardon rear, and 1 u-joint rear), 1 FM-145 transmission crossmember, and 1 set of Dana 28/35 stock radius arms that I got for $150!
Here is what I got done today that was worthy of a picture or two. I needed a new positive battery cable. I had all the parts I used to do this laying around, so another cheap/free mod! The wire from the battery to the starter solenoid is twice the size as it was stock, so hopefully it helps out when I get the new light bar!
Old Battery Cable:
New Battery Cable:
I also figured out why my cruise and horn wasn't working. Turns out it was a bad ground in the steering wheel. Now people will know when I am flipping them off!
danger88ranger
ohio
Whats the thickness on that battery cable? Looks friggin huge!
mjonesjr
Firefighter
Salem, IN
I got the rear done for now. I installed Ranger factory lift blocks I got from Zach (zabeard). They were easy. You wouldn't know it, but the front is only 1/2" higher than the rear!
When I started today:
During:
After:
