Got the buffing thing all figured out today! PetesPonies offered some really good advice that I basically did word for word and it turned out really nice. First thing was to drop the orbital buffer then drop some cash on a nice rotary buffer/polisher by ATD. It's got great reviews and is very comparable to professional buffers but at a lower price ($80). I also ordered a yellow foam pad for it ($15) and some SureFinish compound from Autobodystore.com ($37).
Here's some experimenting on the hood. The left side (passenger) was done with the orbital buffer, the top right was just wet sanded with 1500 grit, and the bottom right was done with the rotary buffer.
This was the temporary shop today. The garage was too dark to see all the sanding scratches that needed to get buffed out so I pulled everything out into the daylight. You can see all the body panels lined up in the garage ready for their turn on the bench.
First step was a wool pad at the lowest setting (1000rpm) with firm pressure (being careful not to burn the clear coat off the edges):
After that I followed up with more compound and the yellow foam pad with firm pressure (always at 1000rpm). Then some water on the pad and very light pressure. Here's all finished:
So paintwork is officially done today!
Next will be the slow process of putting everything back together. It's already too cold for pinstriping and decals so that will need to wait till Spring. In the meantime there are some things that make sense to take care of while it's all apart like a new sending unit, fixing a PO's radio wiring disaster, possibly new body mounts (hint), etc. Still a long way to go on the old B2 and will keep you posted.:icon_thumby:
