Project El Taco...1990 BII
i love the extra weight on the front of mine to... makes it do a little better offroad. but when i get the sas done....... !!!! yay! lol
Ranger Sport Honduras
Zoom Zoom
Honduras
Mazda
Update...
So I needed a little more lift than what the explorer springs were giving me to be able to drive with the LTB's on. I picked up some goodies to help with that:
3.5" Duff kit from another member on here and an SJ AAL for the explorer springs. A set of homebuilt extended RA's as well as a couple of 1" coil spacers will accompany the front lift, Ill get to that in another update.
I also built some HD extended shackles, cost me a grand total of $20. Here is some pics of the construction.
Had to make some new sleeves that were 3" long instead of the jeep bushings 2-5/8" sleeves.
They are roughly 4" longer from pivot to pivot, should give me an extra 2" of lift. 3/8x1-1/2" bar stock, tig welded.
More to come very soon...
u mind if i copy your design? :D
unoleisu
Stillwater, Okla
So, RacinNdrummin, I see this thread has been dormant for awhile, now... but was wondering if you ever did a detailed write up on the SOHC 4.0 swap (with pics ;)? You seem to have worked out all the kinks, and I'm sure I'm not the only one who wants to see it.
I have a 97 EXP with a SOHC 4.0 in my driveway that I'm very interested in swapping into my 87 BII. I kinda need more details before I can convince my self to do it instead of the 4.0 OHV swap I was planning. (Have it in a 92 Exp in my yard)
So I gotta ask, how is the SOHC compared to the OHV?
Hahnsb2
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
His B2 spanked mine on the beach, if that helps :D
snoranger
Jackson, NJ
All 10 are Ford
4.0,5.0,4BT,4.0
They feel about the same down low, but when you get into the upper RPM range the SOHC really is a noticeable difference.
If you drive normally (keep it under 4k RPM most of the time), its not really worth the extra effort and timing chain issues. I personally beat on my truck all the time so its worth it to me.
twoll86
U.S. Military - Active
so to revive an old thread i forgot about this till recently.
what sensors did you retain from the OHV system?
would a 3" body lift allow you to retain AC or is this a no AC swap?
RacinNdrummin
Auburn, Wa
Just for kicks, because a FB thread reminded me....
The B2 Still Runs great... Ive wore out my LTB's, and its still the most reliable vehicle I own :D...
I think I have about 20k or so on it since the swap.
I will have some updates here in the future...
joenorthcarolina
I had to bump this old thread simply because it deserves the attention.
Anyway, He said the A/C Compressor interferes with the power steering gear box. I would assume relocating the compressor would fix that problem.
