Updating the Tech Library Transmission section - Suggestions Needed
Twisted4x4
78, 400; 88, 2.3; 89, 2.3; 98, 3.0
Here is a website Ive found for fans of the 2.3 like myself. http://stinger-performance.com/ Ive found on here that you can bolt a small block Ford tranny to a 2.3 via their bellhousing adapter. These guys are as much into the 2.3 Mustangs, SVO's, and Thunderbird Turbos as we are about RBV's :headbang: They also go into great depth about 2.3 builds and mods to gain more than ever imagined power from these great little blocks. Check em out and see what you think.
cutch9977
Tucson, Az
Jim,
If interested, i could write up a tech page/FAQ on the A4LD, 4R44E/5R55E auto trannys. A lot of questions I see here are very common issues.
please ive tried several time to get someone to tell me where to start with my 4r44e 2-3 shift flare
NixRanger
SouthPugetropolis
who else makes
2.8 V6
How about swapping out the Toyo Kogyo
Read somewhere a while back about doing an upgrade from that tranny but lost it.
Getting estimates of $700 - $1600 to rebuild mine, was hoping to use a trans from a newer year truck, like the M50 or FM145.
Mine's an XL model, 2WD, 2.8 V6, got nearly 300K on my tranny. Shops say there's a rebuild kit available, but what about worn gears and stuff like that??
I'd put Cubewhiz's trans swap write up in, and then maybe splice in my section about the drive shaft swap.
Cube said he used my write up as a guide, but he took much better pictures and many more of them than I did, and most of the info from one FM swap applies to the other.
CHKNFKR
Illinois
545 CID
Too lazy to sign up on blueovaltrucks but i did notice in the tech section over there you have the np435 wide ratio reverse gear listed as 8.02, it should be 8.26. I've counted the teeth myself. I think gwaii can confirm this as well.
also my third gear is 1.74 not 1.66, perhaps gwaii might be able to confirm this as well.
CountryBoy704
V6 2.9L
i would love to see a rebuild guide for the good ol a4ld
85_Ranger4x4
December 2013 OTOTM
SW Iowa
I think it is about the same as changing batteries in your tv remote.
Chuck and replace. :D
Seriously though, I got a neat book that covers Ford transmissions for $25 at the local parts store, very informative.
CountryBoy704
V6 2.9L
yeah i feel ya, whats the name of that book? could come in handy
85_Ranger4x4
December 2013 OTOTM
SW Iowa
I found it, it is a Haynes techbook. I knew it covered a bunch of Ford tranny's but it is basically just the C3-6, AOD and some FWD tranny's but no A4LD. I found it on Hayne's website and gave the local parts store the part number and they ordered it. If you want a book you might check and see what they have if anything for the A4LD.
I got it for my C5 I am using in my V8 swap and it has been very helpfull.
The_Dealer
Macon, GA
Duh!
I'd like to see a writeup on swapping a M50D into an '83-'84 4X4 Ranger. Mainly a list of parts and changes.
i wish i would have taken pics to do a write up on a4ld to my m5od's pedal assembly. dont have much on taking the a4ld out, but i can lay all the parts out and take pics and put together a write up if u would like. i have all my part numbers, and can do a real write up when i go to put things in. i just have the a4ld out, flexplate and spacer off, and shifter removed. havent started reassembling yet. but this does need a good write up with pics. so i guess ill put one together and post it up for u or pm u, whatever u prefer. there are absolutely no pics on first gen a4 to 5spd swaps
CountryBoy704
V6 2.9L
t5 swap piece
maybe add to the t5 swap in tech library?
theres a part sold by summit racing that claims to allow "Standard Ford Bellhousing to T-5 Transmission" - note i have not used this but it looks like we now have another option as the AA adapters were discontinued but they do not specify what applications it will work for
http://www.summitracing.com/parts/MCL-8608/Application/?prefilter=0
briansz
T5 with hydraulic bellhousing is NOT a direct swap in a Gen 1
Just a FYI, I'm about 80% of the way through a T5 swap in my '83 longbed. My truck was stock with the TK4 and I had upgraded to the TK5, which recently began grinding a little in first and reverse.
I pulled my T5 from a 1987 Turbo Coupe and got the bellhousing, slave, mounts, pretty much everything except the front yoke from the driveshaft. I picked up one of those from a 4-cylinder Mustang with a T5 - and it's lucky I did.
The good - the flywheel is the same, the starter works, the '83 hydraulic slave cylinder from the truck is the same part number as the one for the '87 Turbo Coupe. Stock replacement clutch kit for a TC was $92 new (needed due to different spline count).
The not so good - the T5 is 3/4" longer from the face of the bellhousing to the back of the case than the TK5. This might not be a big deal except that the nose of the front yoke from the Mustang with T5 is substantially longer than the one from the Ranger with TK4/TK5. I have another shaft from a M5R1 equipped Ranger and it also has the short nose on the front yoke. I don't feel like there is enough clearance to allow for driveshaft motion due to heavy loads or large bumps. If there isn't enough travel, the large balance ring on the front yoke could contact the tailhousing of the T5, which might be quite bad at speed.
The M5R1 and TK5 front yokes will not slide onto the output shaft of the T5. The diameter of the T5 output shaft is larger.
The stock '83 Ranger crossmember will need some modification to work with the TC tranny mount and the T5 mounting plate. The crossmember is too close to the bottom of the cab by 3/4" to 1". This will require fab work and welding. I'll post pix when I make the modifications.
Obviously the floor pan needs to be modified as well. The shifter is not 9" further back on the T5 compared to the TK5. It's about 3.5" further back. I made a metal plate out of the top cover of a server <lol>, cut out the floor pan, and used my flanging tool to create a lip. Going to get some peel and seal from Home Depot to line the bottom of the plate with.
The TC inner shifter boot does not work well in the Ranger. The one from the TK5 is a much better match.
The shifter handle from the TC needs to be straightened as it nearly hits the driver's bucket seat in 2nd gear if it is not reversed.
I'll talk with a driveshaft shop in the next couple days to see about shortening one of my two shafts.
chilsam
chillicothe il
91 branger
300 six
Im doing the same thing
How did you solve the drive shaft problem? THANXS!:icon_welder:
rednine4
I think putting together a basic rebuild write up on a C4 and C6 transmission would be helpful. Or at least a how to upgrade the C5 to a C4 for firmer shifts etc... just my .02
littlefordman
monroe,mi
4.0l
would any know if i could change my 4.0 auto 2000 ranger to a manual? :3gears::shout:
snoranger
Jackson, NJ
All 10 are Ford
4.0,5.0,4BT,4.0
I know, but this isnt the place to ask about it. This is a thread about updating the info in the tech library. (<------ a good place to start looking for your answer.)
